1 - 14 of 14 Posts
Shifting – it sucks!
I know, it’s only got 140 miles on it but come on! This thing shifts like shite!
Downshifts are getting a little smoother but upshifts are ridiculous! 90% of the time after an upshift, it kind of hangs there. So when I go to upshift again, it won’t because it’s ‘up’ there. I have to downshift so that I can upshift again. Also, it feels like there’s a notch in the middle of the throw in each gear.
Does this sound like the broken shift shaft episode?
Not happy so far...
you might want to do a search on this as I remember someone saying something about the shift rod can break and cause your shifts to act like that its the rod thats inside the tranny ?? I guess they have a weak spot in them and can break.
Why do you need to blip the throttle for a downshift?
Usually my rpms are carrying so high it downshifts with no problem,I'm skidding the back tire so much it's wearing out.
But to blip the throttle in a downshift,in a case of panic downshift,your speeding up to downshift wacko happens more sooner now.
In cruising mode you should be able to upshift below 4k anytime.
Maybe I don't understand the effect your trying to achieve in your style of riding?
Discussion Starter · #11 · (Edited)
Because at 180 miles it shifts like shite!
Blipping with the clutch in doesn't make you speed up.
'cruise mode'?... :wink:
I read the first post and nothing more. Did you drop it on the left side at all? I take it, its a 08 or 09 because of the miles. The shift shaft on atleast the 08's were weak were it bends at the end into a L shape. Causing a crack. This happened to be where if I had to shift up I would press up then have to push back down and up again to shift. Downshifting was the same way just backwards. So if it is a cracked shift shaft this should help.
Try this.
While upshifting make sure you completely unload the shift lever between shifts.. What I mean is make your positive input, then release your foot pressure on the lever, so that your foot is making almost no contact with the lever. I noticed that the shift tends to "hang" if you dont unload it.
Also on downshift it occasionally hangs if you dont have enough RPM. thats weird, i know, but if you come to stop quickly and didnt downshift it doesnt wasnt to:dontknow:
I am not sure y but if u blip as described and release clutch a tad in will drop down the gear.
hope this helps.
:+1: Happened before to other memebers as well, open the clutch basket and check it out.
1 - 14 of 14 Posts
