1 - 2 of 2 Posts
I am selling my "standard" Woolich flash/tuning module for the 2016-2019 ZX-10R. I've since upgraded to the Woolich Log Box package for autotuning capability. This device will provide everything needed to tune your bike, remove factory restrictions, clear fault codes, and more. I've provided a list of features from the Woolich site further below.
Woolich USB M v3 with USB cable - $200
NOTE: To install and use the module you will need to purchase the appropriate harness (I recommend the on-bike harness for $49) and a Bin file ($100) from the Woolich site.
Features available for Kawasaki ZX10R 2016-2018
IAP Fuel Maps
TPS Fuel Maps
Ignition Timing Maps
Ignition Dwell Map/s
Electronic Throttle Valve (ETV) Maps
Fuel Trim Map/s
Intake Flap Opening Maps
Exhaust Valve Opening Maps
Adjust Idle RPM
Adjust RPM Limiter
Adjust Fan Temperature
Quickshifter Ignition Cut Time
Quickshifter - (Requires Race Tools)
Autoblipper - (Requires Race Tools)
Launch Control - (Requires Race Tools)
Pit Lane Limiter - (Requires Race Tools)
Engine Warm Up - (Requires Race Tools)
Race Shift Pattern Sensor Configuration - (Requires Race Tools)
Autoblipper (Enable With Factory Sensor) - No Additional Cost
Disable Evap / Purge Valve
Disable Stock O2 Sensor
Disable Deceleration Fuel Cut
Disable Exhaust Valve
Disable Intake Flap
Disable PAIR Valve / AIS
Disable Top Speed Limiter
Disable Acceleration Fuel Compensation
Engine Braking Control Maps
Enable Race Dash
Tyre Circumference
Engine Data - View Live Engine Data
Woolich Racing AutoTune - (Requires Applicable LogBox + Zeitronix Package)
Diagnostics: Read and Clear Fault Codes - (Requires Applicable V3 Interface)
1 - 2 of 2 Posts
