1 - 4 of 4 Posts
Hi all looking for info for my 04 ZX-10R before changing clutch and dragracing.
Found out a guy can place a shim under the clutch springs to increase pressure a bit. Problem is which size should I buy 10 thousands , 25 thousands or 50 thousands of an inch? MTC sells them as a kit for $16.00.
Any info you can share on this...
Thanks!
Try going to the local hardware store and buying stainless washers for about $0.03 each first.
1 - 4 of 4 Posts
