1 - 12 of 12 Posts
If the Cat is removed from the exhaust-- Im guessing the servo blade does as well?
if a Exhaust system that removes the Cat tottaly is installed--
will this cause an Fi light (dash light) to be on?
any help and/or Direction will be Awesome
thanks!
thanks!
Question 2 is no. Light will not come on unless you pull out the servo (under seat) without tuning light out in ecu. Question 1 I don't understand.
Q 1:
the cat and exhaust valve are ONE unit- correct?
I have not had the time to look under the bike, Just got it yesterday and ordering Exhaust now
Q 1:
Yes. Then 2 cables go up to servo motor under seat. Unhook cables and no fi light comes on. Pull out servo motor and light comes on if not tuned out in ecu.
Thanks-- This is what i was expecting.
So will the Cables completly come out? or will i have to hang them up somewhere (Zip tied)
1 - 12 of 12 Posts
