1 - 6 of 6 Posts
Long shot guys. Looking for the Kawi part number for the tool that removes the inner cap to expose the spring. Trying to change the fork seals and never come across this type before.
Thanks in advance.
Get the Race Tech one, part number TFCH 06. It's better than the Motion Pro for the following reason. There is a notch cut in the nut that allows you to slide the nut over the Reb/Comp rod between the cap and the cup. This allows you to remove the cup without taking off the cap. This helps save you time and you dont have to mess with the adjusters.
1 - 6 of 6 Posts
