1 - 5 of 5 Posts
Hey all! Im having a little trouble figuring out how to remove the shift shaft. Looks like its just held in by a spring? Then again ive read theres a c clip somewhere.. 2006 zx10r. Sorry if this is in the wrong place, hopefully someone here can help! Thank you ?
https://imgur.com/a/4RwNEVV
Hi mate yes there is a circlip on the shaft inside the cases, im not sure if your engine is in or out but the sump needs dropping to get at it on G2. PITA Its possible to drop the sump with the engine insitu!
1 - 5 of 5 Posts
