so im in the process of trying to remove my shift shaft to the upgraded one. ive removed the bolt from the shift linkage and it seems like the shaft should pull straight out. i just want to see if theres any trick to doing this and if theres anything i should be aware before resorting to prying and tapping it out as its not coming out on its own. most likely is as simple as it seems, just want to verify so i dont want to break anything!
