1 - 2 of 2 Posts
I'm running an 06 10r with a pcv, ignition module, and I'm trying to install a quickshift. I ride in Icon field armor 2 boots, they're rather stiff and I have a weak left ankle(broke it 10 years ago). Anyway when I tried to install the quickshift sensor with the dynojet shift rod a(136mm), it's way too long, there's no way I would be able to get my toe under the shifter....
After a few measurements I figure I need a 100mm shift rod. Okay, no problem, I'll go home and order a 100mm shift rod.... Annnnnd I can't find ANYONE who sells a 100mm m6 female L/R shift rod....
Has anyone else run into a similar issue and/or know of where I can find one? Preferably as quickly as humanly possible?
I don't know what your rod looks like but can you just cut the right thread side shorter and use a M6 die to rethread it?
1 - 2 of 2 Posts
