The Sena Prism Tube is a low-profile action camera that allows you to record up to two hours of HD video and audio at the touch of a button.
The Prism comes equipped with both an internal and external microphone to provide excellent wind noise reduction.
Two different camera mounts give you the ability to find the perfect recording position. The main unit has a 125° field of view, where the tube swivel mount provides 360° of rotation.
Voice prompts inform you of the device's status.
The Sena Prism Tube Action Camera is water-resistant.
Included with the Sena Prism Tube Action Camera: Prism Tube main unit, lens cap, rear cap, rear cap for USB cable, Prism Tube USB cable for speaker and microphone, wired microphone, hook-and-loop fastener for wired microphone, speaker, hook-and-loop fastener for speaker, glued surface mounting plate, tube swivel mount kit, Prism USB power and data cable (micro USB type), and allen wrench.
MSRP $119.00
Specifications
Operating temperature:
-10°C - 55°C (14°F - 131°F)
Dimensions:
26 mm (diameter) x 99 mm (length), 31 mm (switch diameter)
(1.0 in (diameter) x 3.9 in (length), 1.2 in (switch diameter))
Weight:
73 g
Optical:
125° Field of View
3.5 M pixel CMOS
Aperture f/2.0
If you have any questions about the product or would like to place an order, feel free to give MIKE a call at 866.931.6644 ext. 804. Is email more convenient? Send us a private message through this forum or write to us at FORUM at RIDERSDISCOUNT dot COM and we'll get back to you right away!
MSRP $119.00
Specifications
Dimensions:
Weight:
73 g
Optical:
125° Field of View
3.5 M pixel CMOS
Aperture f/2.0
