1 - 16 of 16 Posts
Is there a plastic based product that does the same function as bondo? I have a few scuffs/cracks in my bodywork that I want to fill in prior to priming & painting. Is bondo fine? I remember reading somewhere here about 2 months ago that someone wrote about a plastic paste/liquid that solidified as hard as metal. Any help would be great. Thanks!
I used a fiberglass repair kit you can get at any autobody shop. Its a 2 part resin and a fiberglass cloth. You dont need the cloth to fill cracks, but you can use it on the back side to reinforce the body panel. It sands well and takes paint great.
Yankee Racer
+1 same here:thumbsup:
So you just use the resin without the cloth?
Yankee Racer
If you just have cracks then the resin would work but you may want to put some cloth on the backside to reinforce it. I had to use the cloth on mine since I put some pretty big holes in my race plastics. I used the cloth and resin and then covered it over with some bondo, sanded it and painted over it.
Green Hippie
just a reminder if you have a crack stop drill it before you apply any bonding agents or resins :wink:
Green Hippie
Afterburner said:
Thanks Trey! That's exactly the stuff that I remembered from a previous post. You sir, have earned some rep!:wink:
glad to be of service kind Sir :thumbsup:
There is also a process called plastic welding but I was never able to try it.
You essentially drill the stop holes trey mentioned and then sand a V into the body work and melt some abs plastic and fill the hole. You are using ABS plastic on ABS plastic so it goes together perfectly. Sand and repaint or color match the ABS plastic.
I could never find ABS plastic at any hobby shop locally.
CanyonCarver said:
I know it isn't a local hobby shop, but www.eastwood.com carries the ABS welding kit, as well as the ABS welding rods if you just need them and not the kit.
And Eastwood is good to deal with... or at least they were several years back when I got some car stuff from them. :wink:
1 - 16 of 16 Posts
