1 - 4 of 4 Posts
I just installed the Scotts Damper for my 98 ZX9 rebuild, and when its mounted I can not get the key in the ignition.
Has Anyone had to cut thier key just to get it past the damper into the ignition?
yep, on ZX10R as well unless you run the damper 180deg. out....you don't need to cut much but it's required.
bloo
Thanks very much.
I thought I was going nuts here, Scotts should put something more detailed in the instructions based on application.
1 - 4 of 4 Posts
