A unique take on the half-helmet, Scorpion’s Covert helmet is an interesting design that can be configured in three different ways to meet your riding needs. This patented design can be used as a ¾ helmet, a half-helmet, or a pseudo full-face lid by using all of the included components that come in one single box.
Starting with a polycarbonate shell that’s DOT-approved, the helmet is fitted with a drop-down visor that’s interchangeable between clear and smoke lenses, both of which are included in the box. All you have to do is reach up with either hand and pull on a tab to deploy the visor in less than a second. You have the ability to head out ready for whatever light you encounter. If things get a little cold, you can add the included lower helmet portion to go for a three-quarter lid, of if that’s not enough, add the included chinbar for a unique look that’ll keep the wind off your face. The wide-channel eyeport has plenty of room to accommodate glasses or goggles, if you’re so inclined.
Every helmet is fitted with Scorpion’s KwikWick II comfort liner. It’s easily removed and helps channel air to your skull via the integrated vents on the front of the helmet to keep your head cool in hot conditions. Plus, the helmet’s unique design provides an interesting look when you’re out on the road
Backed by a 5 year manufacturer warranty and available in a range of sizes, be sure to get the correct one to fit you by calling TJ on 866.931.6644. You can also send a note to [email protected] with SCORPION COVERT HELMET in the subject line, or just shoot us a PM and we’ll get back to you right away.
