1 - 4 of 4 Posts
I thought I saw a thread with a link to front brake keeper pins that had holes for safety wiring a while ago and was hoping someone could point me in the right direction. I know some people pin the back side of them but are they drilling the holes themselves or buying pins pre-drilled,pins are a little small to be drilling by hand.
I drill mine myself. You will need alot of drill bits though. You will average one a bolt most likely. TQ the pinch bolts down to spec and remember what spec is so if you have to remove them when you tq them back down the holes will line up. Since the caliper bolts are tapered use a punch and mark wear you are going to drill. Pretty simple just time consuming.
1 - 4 of 4 Posts
