1 - 5 of 5 Posts
Any ideas on how and what I can safety wire my drain plug to on my '08 for the track? I'm thinking drilling a hole in the semi circle piece right behind the plug hole. Any other ideas?
I did mine the same way
How or what did you safety wire the oil filter to? Thanks
My 03/04 (and I think other bikes to) had a clamp around the oilfilter. This clamp wasn't on my 09, don't know if it should be normal.
So I used that clamp from my zx6r, the bolt that holds the clamp is drilled and holds a safetywire
Will make a picture when I'm at the garage
1 - 5 of 5 Posts
