So I'm going to condense everything down as much as I can. bike is a 2009 zx10r with 14k miles ish. has PC III(no idea on the tune), K&N filter, and a slip on m4 gp muffler.
prelude to the issue i'm having
I was getting my bike ready for the track day, pulled fuses, removed mirrors, etc... started it up and rode it around and put it on a borrowed trailer on saturday afternoon 9-21 for the track day on Monday 9-23. Weater on Sunday 9-22 was wet, not steady rain, just a very damp mist. The bike remained dry and had a tarp covering it. My track day on Monday was canceled so on tuesday mid morning i went to pull the tarp off and take it off the trailer. Start the bike up to ride it around and put it away and the bike has a really heavy miss like i'm missing out of 2 cylinders. It was really bad.
What I did and tested
On thursday I get some plugs and swap them out, Old plugs were a little fouled but definitely not enough to cause a missfire. Performed resistance tests on primary and secondary coils in the COP's and they all tested good.
After all that I had no luck. I put the tank back on and tried to fire it up but had the same misfire going on. I really have to add a little throttle to get it to fire up and run for more than a second too. Once i let off the throttle it just stalls out.
I remove the PCIII wiring harness and plug my factory harness back in and give it a try with no success.
I do some reading on this forum and other forums and see one person say they've got pin issues at the ECU so today I pulled the connectors at the COP's and at the ECU and ran a continuity test between the wires. I've got good continuity all the way there. Even the terminals in the plugs look really good and clean and seated properly. After doing all of that i kinda play with the connectors on both the ECU and the relay box and the bike pretty much wont even spark up at all. And just as soon as it fires up, it dies. I started to notice a weird almost arching sound coming from the relay box. When I started to hear that noise I decided to kinda play with the plug that has the red wire going to the COP's and the bike would fire up and run like on all 4 cylinders and die out pretty quickly. but with the bike running I dont hear that arching noise from the relay box, only when the bike begins to die/misfire/stall out do i start to hear that noise.
I'm really looking for peoples opinions on that relay box and if i should try and find a replacement/anyone in my area that might have one I can swap just to see if thats what it is. I live in The Plains VA and work in Fairfax VA. Pretty much work every single day of the week or at least I have been doing that for the last few weeks.
Thanks in advance for any input! And sorry this is soo long I'm trying to be as descriptive as possible and give as much information as I can.
