1 - 6 of 6 Posts
What's RPM's web site thanks, anybody running there oil pan?
I had one on my bike worked well just watch the pickup. Ive heard that the fall off. Never happened to me but heard it has
I bought one used and the o-ring that came with the pickup (i don't know if its the one RPM provides) would not have sealed it to the motor so i cut the bottom of the factory seal off and made my on o-ring. If you get one you will see what im talking about. I also heard of them falling off so i drilled and tapped another set screw and used lock tight. I was kind of paranoid so i welded a slug to the bottom of the pan so if for some reason it did, it wouldn't fall off completely and i would see a drop in pressure. I havent had any problems .
thanks guy's thats why i was asking, i have a friend that got one for sell but i heard some of the same stuff, I was told that you have to pull them down and keep a eye on that pick up, thanks again:thumbsup:
you can call adams and they will cut your stock pan and put a pick in it for 150.00.....
1 - 6 of 6 Posts
