1 - 5 of 5 Posts
Installing my Bazzaz QS TC this weekend with the self mapping kit and this is my first time around installing a piggyback on a bike and i have a few questions.
Any tuning i have done on cars is easy--- because dyno or not-- you could have another person drive and tune at the same time. Every Bazzaz how to video on their channel has it on a dyno where you can run the program and the bike simultaneously.
Can I data log without having a laptop plugged in, pull up my changes when i stop and edit/load from there? AKA trackside changes....
Also I have a BMC filter and a full system. Does anyone have a recommended starting point on target afr? All motor cars i would tune in the 13.5-13.8 range, and I would adjust fuel for cruising speeds to 15.0. I dont want to assume that the principal carries over if it doesnt.
Ideally the initial map should be built on a dyno- but i dont want to drive lean... I will post this on their forum as soon as i get activiated but i didnt get an email from them yet.
Any help?
Yes. Click the SELF MAPPING tab, then Start, when your connected to the bike. Unplug, ride. Plug back in. Click SELF MAPPING tab , then Retrieve (or Stop, then Retrieve). Make changes if wanted.
Cant really answer your AFR question. That would be lean tho, wouldnt it?
Supercharged Mod
There's no fundamental difference between a modern bike engine and a modern car engine - the bike engine ist just smaller and spins faster. Air/fuel ratio - Low 13's under load, 15ish at cruise (20% throttle and below) is fine but it won't want to idle smoothly that lean. I always start rich and then sneak up on leaning it out.
Thanks very much for the info--- I am converting from a PC3 that came installed on the bike to the bazzaz and cant wait!
1 - 5 of 5 Posts
