1 - 12 of 12 Posts
I bought a set of Shinko slicks , I went with the same front tire size but couldnt do the same rear size ( 190 60 17 ) I went with the 180 55 17 other option would have been a 190 50 17 .
Question : Did I screw my setup with the thinner tire , Should I have run the shorter side wall wider tire .
Which size tire would be a better fit ? :dontknow:
Not too late yet I can still order the correct size
Thanks :thumbsup:
Don't buy shinko tires period. You need a 190 rear tire. Bridgestone Pro's are going for $315 a set now...way better than those tires.
your bike will feel real funny but not in a good way...
it will probably:
wont be able to finish the turn correctly
shread the front tire up
be a pain in the ... to stear
plow into the turn
etc...
there's great % difference in ride height between a 190 60 and a 180 55 and you'll trow your geometry way off....
and the 190 50 is even worse
just my 2 cents
Thanks guys
So tires are crap and wont work for me :thumbsup:
P 51 Jockey Where can I find Bridgestone sets and I m guessing they have a 190 60 17 size slick ?
Thanks guys
The southwest distributor can ship to you. Call 866 cyclemall.
Or maybe Sportbike Performance Center can help you. 602-569-3070
The 003 dot's would be better as they have been updated recently and the slicks have not. The 190 dot doesn't call out the profile, but the slick is a 190/65.
You will probably crash on Shinkos...seriously.
Just a thought. All these guys who say you'll crash on Shinkos, have any of them ever even ridden on them? Just curious.
Discussion Starter #10
He did say Probably crash , I dont know I hear the same thing from everyone .
Anyone get the new pirelli slicks yet? no tire warmer required?
Wanting to give these a shot for trackdays and the fact the heat cycles dont effect them has me sold!
That would be the Pirelli Pro slick your talking about. I have used that tire on several occasions and for a track day tire it works great. It lasts a long time as well. I was getting about 3 track days with a rear and about 5 track days out of the front. You don't have to use tire warmers at all and the warm up time is real quick. after 1 lap, you are ready to roll. I did eventually buy a set of warmers and that helps with the tire life and grip level over time considerably. I would consider this tire to be an entry-level endurance race tire equilivant. If your just hitting track days, this tire is for you.
1 - 12 of 12 Posts
