1 - 19 of 19 Posts
Awesome seller would definitely be buying more from them! Mike is great salesman with tons of information and what can I say about the best prices around! Recieved my TechSpec and my ZG Corsa the other day just installed it earlier heres some pictures, couldnt be more pleased with my purchase. :thumbsup:
Thanks again Mike!
Squid wannabe
The only problem with them is that they take all my money!
You can't beat their prices!
All show and all go 10r
Well usually they're mounted to the exhaust hanger and you don't have one so that kind of changes everything. The line should be resting under the subframe not moving with the swing arm.
Squid wannabe
I am confused too. Maybe he mistaken the pre load adjuster line with the brake line (since there are two, one for the brake line and one for the sensor)?
The line for the remote preload adjuster for the rear shock looks like its sitting on top of the rear hugger. When your suspension compresses it'll slowly wear the line.
Discussion Starter #9 (Edited)
Might touch on big ones but as it sits there's about a 1/4 inch of clearance between the hugged and the line. Wire looks unscathed so far.
edit I do plan on adding the pillion pegs back on and mounting it with there preferred zip tie method. Need to.find a bolt and.rubber for.the hole
Discussion Starter #10
Edit I re ran the remote and added the bitch pegs.
Zip ties ehh idk but this is the preferred install method by ohlins.
That weird man. You should remove the closest zip tie to the sub frame. You need more slack on the line. It's going to pull on it and the line is going to end up holding your swing arm, when the bike gets light.
Discussion Starter #13
OK I re ran it bounced the bike all the way down up etc there's plenty of clearance now. Thanks for looking out man
Squid wannabe
Oh, i see what you guys talking about now..
ZX-10R enthusiast
Discussion Starter #16
Sony Xpedia ion 12.0mp mode with soft hdr enhance setting. Its a phone. Lol
ZX-10R enthusiast
Thanks again Mike!
Thanks for the write-up, I appreciate your support! Bike looks great by the way!
1 - 19 of 19 Posts
