1 - 10 of 10 Posts
I need to replace my chain and sprockets. I purchased the bike with -1/+3 sprockets. I love the low end power right now but I really don't love the 25mpg I'm getting nor the 7k I'm at in 6th gear at 80mph. Has anyone out there gone from a -1/+3 setup back to stock? Maybe a better option for me would be to get a -1 front and stock rear? How much of a difference would the gearing swap make in MPG's? I ride it a lot and a significant MPG increase would trump some loss of performance. Trading it in for a scooter that gets 80mpg is not an option :headshake but I'd like to have the best of both worlds if possible.
properly tuned my zx10r was getting 42ish mpg with 16/40 gearing.
which Gen is this on?
Austin, my drag sprocket is 44 (+5) tooth, which puts me slightly more acceleration biased than -1/+2 gearing. Ive ridden with it on the street for quite some miles too. Its cool. The only difference that really bugged me when I put the 39 back on the rear, and Im stock gear for the street, was it was a little more difficult to get the bike to start rolling in 1st gear. Other than that, its very easy to live with gear IMO. Its still a very fast bike and very lively on the street. If you just kick it down a gear, its just fine on the street. On the highway going 80 indicated Im at around 5100RPM, more or less.
Damn, that'd be very nice. I have a powercommander, maybe a little tweaking is required? I don't see how 2 rear teeth would make that big of a difference between our bikes. Also has a full system, velocity stacks, air filter etc. You had a speedohealer right? How'd you get better than stock mileage with lower gearing?
Yeah you putting like 3 gallons in your bike after going 120 miles is what got me thinking about swapping back to stock.
keep in mind though, mine was about 44 mpg on the freeway only. aerodynamics also play into it. Your body is like a giant air brake on these things and does decrease mileage. Tuning can definently help with your MPG though. When was the last time you changed or cleaned/oiled the air filter in the bike?
True that, I do feel like I'm a sail on the bike when I'm on the fwy. I've never cleaned the airfilter but it's a K&N and only has 5-6000 miles on it. I'll check it though.
I do mine about every oil change. I dont mind the work getting into the tank and all either though.
Gen2 Ripper
5k miles on an aftermarket airfilter probably does need cleaning. I began to clean mine evry oil change too. Takes less time to clean/oil airfilter than to change oil. My filter,pipercross, gets filthy if I wait 5k miles. Pretty much clogged at the ram air tube portions of filter. PiperX uses a TACKY oil on filter since it is a foam filter. Has large poors at the front of filter and then has a second stage on inside which is TINY little poors which doesn't get oiled. Only the ram air duct side gets oiled on mine.
1 - 10 of 10 Posts
