1 - 6 of 6 Posts
I have a 2008 zx10r, strip only bike, after looking at different threads, do you guys think removing the secondary butterflies would help at all on a strip only bike. Some of the other threads said it helps more in mid range but not up top. Just wanting to know what you racers think and know. The bike will be running this race season no filter, open header, pcv with custom map, msd launch master, shift light and hopefully pingel electric shift. All info appreciated.
Speed Freak
yank em!!!!!
If you can and have the $ send the ECU out to get flashed, they pull abour 4* timing up top so your missing out on some power and faster times!
pull em out and switch out the 2 tall stacks in the middle for 2 short outer ones.
thanks for the quick answers i'll be taking them out when its torn apart i the next couple weeks
Learning alot about the zx's, totally different beast than I was used to, always dragged Harleys before, thanks again for all the info you put out, where would be a good place to send my ecu to garth
1 - 6 of 6 Posts
