1 - 5 of 5 Posts
has anyone removed the lower butterfly's from the throttle boddies? if so any gain or loss? if so where ( low mid high?)
definitely DO NOT remove the lower throttle butterflies. those are the ones connected to the throttle. if you remove them, then engine will blow itself up with in 30 seconds of start up. you want to remove the electronically controlled UPPER butterflies. i haven't removed them, but those that have have reported better low end throttle response, and slightly higher peak numbers, usually, 1-4hp depending on the amount of other mods done.
lol i just looked at the throttles yea i meant the the uppers if i removed the lowers i would be wfo from jump sorry im still laughing at myself
1 - 5 of 5 Posts
