1 - 16 of 16 Posts
do any of you drag racers have your radiator fan removed? just curious because my new exhaust doesnt clear my fan and instead of dremeling my bracket i was wondering if i could just remove the fan altogether.
My bike is a drag bike only and NEVER sees the street
Speed Freak
do it, will save 2 lbs :)
I used to not roll around with it on my 04 10r during the cooler months of the year. As long as you dont get her to hot you'll be fine
:+2:
The fan only hits when over 210degs....if your running that hot the bike should not be running in the first place the ZX10Rs run best at 160deg anyway. :wink:
bloo
I wonder why some of the drag racers use ballast weight? Seems like the fan is a small bit of ballast. Should just remove the gas. Too much ballast too high with no baffles.
1 - 16 of 16 Posts
