Yep, just removed one of the springs (black 3 prong piece of steel). Also lowered the engine braking.Simply removed?
That should be a substantial enough change to notice. If it isn't enough I'd take some engine braking out.ok, I removed 2 springs , in 2 weeks I'll try the bike at Mugello Circuit and let you know
I would go 1 at a time....
you could end up with the clutch slipping under acceleration
