1 - 3 of 3 Posts
Hi,
I recently bought a salvage 04 ZX10R that i am turning into a track bike.
Just wanted to know how people are running there bikes without the headlight assembly. Do i need to cut into the harness?
Thanks for any help.
No, should just be a connector or two. Just trace your wire to the appropriate one and disconnect, remove headlight, and you're done. I'm sure you'll get a much more detailed answer soon, but if I recall, it's pretty simple.
i run mine without the headlight assembly. Headlights are on the fairings by the way of 6 - 8 bolts, undo them, the headlights come off, unclip the bull connectors and you're done. You will have a bit of dangling wires, but I just tuck them away on the side, you have a crap ton of open /empty space now that the headlights are gone, not to mention, weight is gone too!
1 - 3 of 3 Posts
