If you removed the nut from the other end then the bolt should just pull through or maybe a tap from from the threaded side where you removed the nut might move it but if the weight of the engine is still on the bolt then it may all tumble out.
Cheers mate...Yeah bike is supported by a swingarm center lift (Abba stand)If you removed the nut from the other end then the bolt should just pull through or maybe a tap from from the threaded side where you removed the nut might move it but if the weight of the engine is still on the bolt then it may all tumble out.
