1 - 11 of 11 Posts
Ok, fellas!! I just recieved the Ohlins Rear Spring the I got off of Ebay. The one that going for like $30.00. My question to anyone is: How do you remove the spring off the rear shock? Thanks in advance for all who replies!!!!:eek:ccasion1
Discussion Starter #2
Also guys please give some good detailed directions!!!:thumbsup:
are you putting an Ohlins spring on an Ohlin's shock or stock or Penske. Perhaps a few more details on what you are doing and trying to accomplish?
Support the rear frame of the bike(not swingarm).Remove shock.Loosen the 2 preload adjustment nuts(located on top of the spring).After spring is loose push up on the bottom retainer ring.Remover retainer wire clip.THAT'S IT.Pull it apart.
Thanks a million!!!!:eek:ccasion1 Also it's for my stock shock!!!! Thanks again!!!
Is there a big advantage to be gained using the Ebay Ohlins spring on the stock shock? Anyone know the correct spring from Ohlins for the 06/07 for a rider at 190-200lbs?
Your welcome,glad I could help.So how do you like the new spring?
MIA Ex-Mod
Did you ever find out what the stock spring length was? Any visible flaws on the Ohlins spring?
Tread
It rides nice. I feel so much better in the curves. Feels like night and day. My friends cannot believe it's still on the stock shock. My shock is the shock off of the 05 zx-10!!! Thanks for all the help fellas!!!:thumbsup:
MIA Ex-Mod
So what is the stock length of the shock? Also what length did you order?
1 - 11 of 11 Posts
