1 - 8 of 8 Posts
Hello,
Using stock wheels, has anyone found/made or come up with a solution to put the rear caliper on the bottom of the swingarm? Zx12r maybe, zx14r not, Attack whatever! Spacing on brake caliper isn't important: stock or Brembo. If anyone can fabricate (will pay through paypal) or point me in the right direction it will be greatly appreciated.
Thanks
I appreciate your response and the info you've provided. There is a company in Japan that allows you to use a Bremo (less 5% of the pad area so the caliper is mounted lower for clearence) but it's expensive. I was hoping someone had a similar experience as me and I could find someone who can fabricate or modify. Again, thanks....SBK and Motogp and......Formula 1 this weekend!
Well our buddy garth has done this mod and id like to know as well. Hopefully he will chime in.
Licensed Dist of HaterAde
:+1: that's what i was thinking when i first saw this thread too BUT i'm pretty sure he had aftermarket rims and was using the brembo rear caliper as well......
The one that Garth has requires you to have Marchi's on, I have seen PVM advertise one that you can get, but I dont know how compatible it is with the 04-05 swing arm and stock wheels.
The ZX14, I believe has a different inner rim Diameter, so that wont work.
CARROZZERIA does not make em for the Kawis.
I've had mines (ladybird) for a while but its not a perfect fit, im ok with it cause I don't use the rear brakes enough.
I know there is a Brembo bracket for the 08-10 models but that requires you to change the rear swing arm.
I have talked to Champ about making these, which reminds me, I keep forgetting to contact him for the rest of my parts. So champ, if you see this, oops.
1 - 8 of 8 Posts
