1 - 6 of 6 Posts
Regulator Rectifier !!
Is there any way to test this to see if its going bad?
Under low RPM's Im getting flashing or no gauges...
(just got a new battery)
thanks...
dosn't sound like a regulator rectifier. chech the charge rate should be aound 13v. maybe loose plug / treminal some where. give us some more info
its acutally for my wifes, 99 R6.
just replaced the battery 3 days ago.
checked the ground to the frame, looked good.
Didnt see any loose/woren wires....
Put a voltmeter on the battery with the engine off. Then start it. You should see about a 1.5V increase with the engine running, around 14.5 volts. If it doesn't increase then the battery isn't getting charged. If the alternator is internally regulated you will have to replace the entire unit (assuming all wiring is good). The 10R has an external reg so its easier to replace. HTH.
1 - 6 of 6 Posts
