1 - 2 of 2 Posts
anyone can help to explain what is going on? red light below signal light of my zx10r 2011 turn on even when the engine start. usually the light will turn off after engine started, thx in advanced
Premium Member
'16 ZX-10R KRT
Well, there's not really enough information given in the post.
If the red light is on without the "FI" warning under the speedometer, then that means there is low oil pressure in the engine. Any time that red light comes on by itself when the engine is running means you need to turn off the motor immediately to prevent catastrophic engine damage.
If the red light is on with the "FI" indication at the same time, there's a problem and an error code to tell where the problem is.
1 - 2 of 2 Posts
