1 - 5 of 5 Posts
Most aftermarket rearsets go up and back from stock location.
If you are handy with a caliper and know a good machine shop you can make your own brackets for probably $100 or so.
The Pace
Hi, has anyone of our taller frineds here found a good rearset with a bit more room than standard?
2014 model
thanks
Gavin
You have gen 4 that should have adjustable rearsets. Set aside time and grab some light. Remove right rearset and you'll see several hole patterns. You want the lowest. Left side you may have to loosen shifter. Do same.
If you know how far back and down you'd like to go, i could probably put something together for you. PM me if youre interested, i did something very similiar on my zx9r last year, made a set that uses vortex pegs/shifter/brake pedal for my track zx6rr and retrofitted gen 4 zx10r rearsets to my dads 77 kz1000.
EDIT: this will use the stock rearsets but have a bracket the rearset will mount to that will mount to the stock locations on your frame.
1 - 5 of 5 Posts
