which is your fav.?
  • 180/55
    Votes: 11 22.4%
  • 190/50 (stock)
    Votes: 27 55.1%
  • 190/55
    Votes: 7 14.3%
  • 190/60
    Votes: 3 6.1%
  • other
    Votes: 1 2.0%
  • Total voters
    49
1 - 15 of 15 Posts
i just wanted to see who is playin around with tire sizes. what size? how did the 10 respond (w/ proper suspension setup)? any body switch only to return to stock size? do you run different size at track only? overall opinion... i know.... alot to do with preference here, but i am considering changing size to 180/55 or 190/55, hopefully this will help me as well as others........ :mrgreen: :zx_green:
MIA Post Whore
Love the 180/55 (Pilot Pwrs). Works great on the street and makes tha bike feel the way i like it. The 190/50 just didn't fit my taste.
btw- I made no geometry changes.
I run the 190/50 but I was thinking of trying the 180/55. I see the new 10r is running a 190/55 and it is supposed to help with traction while leaned over. I dunno?!!
Hillbillie Mod
190/60. Dropped rear and front. SUPER DRASTIC GEOMETRY.
I love it...just gotta be uber smooth on the gas. Penske Rear shock helps alot of the shakes.
Like the 180 PP. Just when exiting a corner be easy on her or she will spin up
:1848:
Discussion Starter #8
thanks for all the replies.... im really leaning towards a 190/55 next time, which is more of a drastic suspension change (requires proper setup)/more expensive/increases inaccuracy of speedo more than a 180. has anybody tried both of theese sizes? is the 190/55 really worth it?
its just a personal prefernce really. i just like the 180 better because the bike turns in a lot easier. From what i have heard the 190 is more stable at higher speeds and wheelies but I haven't really noticed a differance. Just go with what you are comfortbale on.
Hillbillie Mod
IMO, it depends on what you do...how you ride.
If you never go to the track...Id save your money and buy 180/55s cause theyre cheap.
If you go to the track alot...I would start looking into a bigger tire...IE, 190/55 190/60.
Discussion Starter #11
well i'll be hittin the track next year, which is why i wanted the bit bigger tire... as of now 190/55 will be my next choice
Ah yes, the 190/60 is the shit. More traction coming out of turns fo sho'. I like the 180/55 also but they don't have the lean angle of the 190 on my setup.
Rear raised 3mm and front dropped 8mm.
i have a 190/55 rear stock height (besides the taller tire) front dropped 3mm.
end of next year i'll go with the 190/60 with the front raised 2mm from stock.
Where can you get 190/60's at right now? I'm seriously looking at this for my 636. I've seen 195/70 slicks on one and they actually fit. :eyecrazy:
190/50 Shinko 003 for drag racing none the less!!! :helmet:
1 - 15 of 15 Posts
