1 - 7 of 7 Posts
Hi all,
Wondering if anyone might be able to help me, I’d like to find out what the general working range (pounds per inch or kg/mm) is for rear springs in the ‘06-‘07. My interest is in solo riding, primarily track work.
Reason for asking, I have a titanium rear spring that I was running on my old ZX7R superbike, which I’m keen to install on my incoming ’07.
Thanks,
Brian
Rent this space
Approximately 500 lbs/inch and a 3:1 motion ratio from tire to shock.
The easiest way to check if its compatible is to stand on both and see if they have the same measurement of compression.
Thanks very much guys. If that number is the standard rate, then my 9.5 should work fairly well in a track environment at a middling pace (albeit given I weigh over 100kg, I imagine it will be a bit soft if I can ever get up to a decent turn of speed).
Cheers,
Brian
Hidey Ho!
Check out www.racetech.com and do a spring rate search for the bike. It atleast puts you in the ballpark.
Stock as measured is apparently 8.3kg/mm (x 56) = 465lb/in.
Racetech recc for 100kg racing plus gear is 10.24kg/mm = 573lb/in.
Hope that helps mate.
Cheers
Thanks mate, interesting indeed. Given I'm more of a wobbler than a racer, and I've already invested far too much money in the ti spring, I'll give that a go first ; if it's no good it can go on my ZXR trackbike, but I should at least give it a shot.
And I'll ignore that previous jibe on the vegemite, a kangaroo steak and a bucket of prawns are far more enjoyable ! :lol:
Cheers,
Brian
1 - 7 of 7 Posts
