1 - 5 of 5 Posts
Looking for a way to up grade/improve my OE shock without spending a small fortune, I've not heard bad things about the Gen 4 shocks in the same way you hear for Gen 3 are they better then Gen 3?
If so will a Gen 4 shock fit into a Gen3?
Discussion Starter #2
Sorry Admin I should have posted this in suspension section could you move it please :smile:
Not sure where you're getting your info, but the G4 shock is pretty bad. It's set up and sprung very light. And no, it won't fit on the G3. The reservoir is completely different and would interfere with the swingarm.
Get your rear shock resprung and revalved and you'll be good to go.
I've not got any hands on experince with the Gen 4 shock just not heard anything bad about it unlike the Gen 3.
I started a thread yesterday on my G4 Shock Ohlins v re-valve it pretty much answers the question about your shock. My shock is max out on the heaviest settings for dampening and rebound and its still not good enough. I am just debating of going ohlins or re-valve.
1 - 5 of 5 Posts
