1 - 6 of 6 Posts
2008_0109AD.JPG Hi -Y'all - Newb to ZX10R.net here !!!! I bought a used '06 ZX10R and am about to install an aftermarket shock. There is what looks like a shim between the shocks top mount bracket and frame. Is this factory or has the previous owner installed this ? Any and all feedback much appreciated - thanks !
View attachment 55657 Hi -Y'all - Newb to ZX10R.net here !!!! I bought a used '06 ZX10R and am about to install an aftermarket shock. There is what looks like a shim between the shocks top mount bracket and frame. Is this factory or has the previous owner installed this ? Any and all feedback much appreciated - thanks !
Yes it's factory and :welcome:.
Sometimes you need to remove it. Depending on what else you change. The shock manufacturer should be able to tell you. I know when I went from a 55 to 50 tire I changed mine to correct for the geometry change.
like the ninny said its OEM and depending on what aftermarket shock you purchased you may want to remove the shim or leave it.
:nana:
:+1: Different tire manuraturer has different profile too my DC III I've added 3mm with mine, can't wait to try it :mrgreen.
1 - 6 of 6 Posts
