Hey I want to order a stiffer spring for the rear shock spring from Faulkner as they seem pretty cheap and the website needs you to add the specs of spring you want.
The choices i think are correct are 7 inch(177.8mm) free length, 2.25(58.5mm) internal diameter and 650lb(114N/mm), i couldn't find much info about int diameter.
Are these correct? Im 96k nekked or 212lb to you Americans and will be riding mainly street but want it stiff enough for track days afew times a year.
The link if anybody else wants try one
http://www.demon-tweeks.co.uk/motorcycle/rear-springs/faulkners-race-springs
