1 - 5 of 5 Posts
Ok, it's been doing this since brand new(8/2010), but it's getting worse.
intermittently, I step on the rear brake and there is an initial "pedal" or resistence felt, then a "POP" sensation and the pedal drops more.
Only drops an additional 1/4" - 3/8" and does not affect the "grab" but it's un-nerving!
Used to do it 1-out-of-every-10-times, but now it's about one in three. So it's getting worse.
Things I've already tried:
1. bleed
2. flush out/replace all fluid
3. adjust MC actuator rod
4. check & re-torque caliper
5. check & re-torque rotor
6. remove, sand, and re-install pads with new pin grease.
7. remove heel gaurd.
No dice. still "popping"
Ideas? suggestions?
I wonder if it's the pedal itself ? Perhaps the pivot needs a bit of grease. Alternatively, could the brake light switch be adding a bit of inital drag ?
Cheers,
Brian
Cheers,
Brian
Good idea on the lamp switch, I'm going to investigate this.
Is anything bent?
No, nothing bent or damaged. Its done it since I uncrated it this past summer.
All show and all go 10r
I'm just gonna say that there is still air in the line. I've bleed the shit out of my brakes and when it sat for 3 months a half inch air bubble was in the clear hose between the mc and brake reservoir.
1 - 5 of 5 Posts
