1 - 9 of 9 Posts
Anyone know what length the SS rear brake line will need to be if I stretch my zx10 with 3-9" links???
I need the best price on one...and where i CAN order one???
Thanks
Russ
I don't know the length you need but one of the sponsors here could probablly figure it out for ya. They're cheap too.
The Galfer rear line i purchased earlier this year was much longer than the OEM AND one fitting was not assembled @ the correct angle so i cut about 2.5" off and installed a universal banjo fitting at the MC end. The line is now roughly 19.5" including the banjo fittings. I've also extended my wheelbase with a +2 link chain so this could help in your case.
MIA Post Whore
Bd-how old is that pic? I'm curious as to why there's no color change on your midpipe. My stock mid pipe blued up with only 1K miles on it.
pics taken with 1.2k :dontknow:
of all the custom lines i've made none have ever had leakage. A small to med vise is a big help but not absolutely necessary, a dremel tool W/cut-off wheels for the line and some patience will do the trick.
1 - 9 of 9 Posts
