1 - 2 of 2 Posts
I just changed my rear brake pads. As I was bleeding them with bel-ray DOT 4 I noticed that one of the rubber boots was bubbling brake fluid when the rear brake pedal was depressed.
Can this be fixed with new seals, or should I look for a new caliper? Leak is indicated in the picture.
Licensed Dist of HaterAde
That's a new one to me man.....I would think replacing the part or a seal would fix the problem BUT i'm not sure if you can get that piece or part from an O ring/rebuild kit or not?
1 - 2 of 2 Posts
