1 - 14 of 14 Posts
hey guys. i just picked up a 08 10r. it has a adams arm stretched about 8'" full exhaust and lowered in the front and back and a filter. stock gearing but ill probably go down 1 and up 3 after a few months next spring and add an air shifter. trying to come up with a pretty good goal for the 1/4 i was thinking around 9.4. im about 155 suited and was cutting 1.5's 60 's with my 07 gsxr 600 in the 8'th with a best of 6.71. is that a pretty good goal for the bike? i know the bike is well capeable of better than that and the times will improve with more time and feel for the bike, im just pretty new to the zx world. im gonna ride the bike every day so i dont really want to touch the motor and go that whole route. just looking for a little input on the times i could expect.. (keep in mind i know it all depends on the rider but im not new to the whole 1/8, 1/4 mile thing, but by no means an expert)
Slow Poke
You need more gear. Put a 15 on the front and it'll be crazy. I'm sprayin mine with a 15front and stock rear. For the motor you should do -2 +2 a lot of guys will say -1 +4 or somethin but I've had great luck with a 15 on the front. Just IMO.
I think the way your bike is setup once you get used to it and some seat time 9.40's will be very attainable at your weight.
thanks for the quick response guys, i have read that these bikes need the gear in 1st b/c its so long... would -2+2 be about the same as -1+4 though? cant wait for next spring though, have a few cosmetic things i want to get done. the bike has chrome rc wheels i need to sell and pick up a set of stockers, and slap a hook up on the rear. had a lot of good things to say about my shinko stealth on my 600 so sticking with shinko. and probably later on in the season once i get use to the bike and running it how it should be ran probaby throw a little shot of spray at it with a tune!! never though id switch from suzuki but im excited.
Slow Poke
1 tooth off the front is between 2-3 off the rear. Like I said some guys would rather go bigger on the rear than smaller on the front. I personally swear by the 15. However it doesn't like clip style master links. Since its so small it likes to pop clips off. I have a clip style on mine. But just siliconed the plate on there and it seems to be doing fine. Shinko's are hard to beat at the track, but if you have the money power ones are lighter and hook just as good if not better IMO.
I think you'll love it man. Just get some seat time and you run good. Personally 5.90's in the 1/8th was a pretty big feat for me. But that may be just me..
like magma said throw a 15t on the front and dat bitch will fly off the line. i was runnin -1for min till magma told me to try a 15t, once i went -2 on the front ive not look back since lol.
I have a 2010 10r with a 12in arm and just bolt on mods. About the same weight as you and I run very consistant 5.73-5.74 in the 1/8th. 87 pump gas as well. Seat time is everything
And a 12 over arm is a BIG help too. :lol:
So would a built motor :rolleyes: spark plugs have never even been out of my motor and I run cheap ole shell 87 pump gas. Arm or not, I feel as though my bike is doing awesome for what it is.
Slow Poke
No reason to get all defensive. But it's a lot easier to go fast with a long arm.not taking anything away from you at all. Your definitely riding that thing. But doin it with a short bike is a lot harder and definitely impressive. It's easy to go fast with a long arm. Built motor doesn't help much at all if you can't put the power to the ground.... Cheap ole 87 huh. You know a bike runs faster on 87 right? :rolleyes:
I have a 09' 15/43 gearing, 180 hook up, 7 1/2-8" back. Stock engine, NO AIR SHIFTER.... 2Bros midpipe and muffler. -2+2 works good for both short and long tracks.
My wife is about 150ish...LOL SHH..... and runs 6.10s in the 1/8th and 9.7 in the quarter.
I just ran the bike yesterday and haven't rode it in 4-5 months. My best time was a 6.25 1/8 and 9.62 1/4 mile. The bike has the potential, just knowing the bike will improve your times.
Bgmagma:
Is it no good for the motor running that low of an octane though?
Not denying that they will run faster. The Gen4 manual says not to use anything under 90.
I'm always using 93 though. Am I losing some power there? If so, what approximate numbers are we talkin?
Slow Poke
Bgmagma:
Its fine on a stock motor. Higher compression motors I wouldn't. I run 91 in mine on the street now. But a stock motor will be fine on 87 and it will run better. Only time a bike will really detonate is on a really hot day in high gear with a big load on it. But in normal situations 87 will be completely fine.
1 - 14 of 14 Posts
