1 - 5 of 5 Posts
I'm hooking up a raptor shift light thats what the unterminated white wire hanging there is coming from. The other 2 wires are coming off of the wheel sensor plug, which one of the 2 is the vehicle speed signal? Or are you guys hooking it up in a different area? Gen 5
447986
Uh. I think you've got it bass-ackwards. You connect a shift light to the engine RPM signal, not the wheel speed. That gives you no information. You shouldn't be using any of the wires coming off the wheel speed sensor.
Discussion Starter · #3 ·
I already have a wire getting signal from the coil.. this is the signal wire to get the light out of launch mode after you take off and go into a regular shift light
I'm not familiar with the shift light and why it would need to be tied into the launch control, but whatever. The signal line from the wheel sensor is the white/green wire.
Discussion Starter · #5 ·
All its doing is sending a signal to the shift light once the bike starts moving to tell the shift light to get out of launch mode and go to shift mode
1 - 5 of 5 Posts
