1 - 3 of 3 Posts
Hello out there. I just picked up an 05 and last night I'm going over some basic maintenance.....come to find out the connection surface of the ram air tube is cracked and broken! To clarify, it's the plastic section of the square ram air tube that you insert into the metal section below the triple tree. There are three fasteners on each side to hold the nose section in place. The entire are on both sides is cracked and broken, so there's nothing for those fasteners to hold on to!
If anybody has seen this similar problem out there or can recommend a fix, I would be GREATLY appreciative. Right now I'm stuck about how to fix it. Thanks!:eek:ccasion1
1 - 3 of 3 Posts
