1 - 13 of 13 Posts
i could be wrong but that looks exactly like what ducati uses. i never seen what pro riders used. maby that is it? if it is i had higher expectations from them.
+1 Zeotrix,
Most of the ones being used are magneti marrelli and l1098/1198 looks liek them as being its the same company.
you will see a few others as well, which are typically the bikes using a Motec system on them.
the AIM unit is about the closest most will get being it can work with your bike stock, But if your down with $$$$ you can go here.
http://www.motec.com/products/productoverview/
Starlane makes one. Not the easiest thing to install. You can get the race kit ones from your bike's manufacturer. These dashes just aren't instrument panels. They have some computing power in them. The ECU manages the motor but the race dashes store telemetry and cache information from the ECU. On a lot of newer bikes you can't run them without the dash and the ECU.
1 - 13 of 13 Posts
