Hi
I have a 2016 with race kit ecu and wiring loom. Now it won't rev past 5k rpm :frown2:
In neutral it is just like it hits the rev limiter at 5k. In the lower gears it's the same but higher gears even less rpm, in 6th it only like runs on idle and if I open the throttle it hits limiter directly.
The problem is there are no warning lights and no error codes in display.
I have turned off tc and still the same.
Anyone have any idea what could be the problem?
