1 - 2 of 2 Posts
I have the Woolich box set up on my 2017 ZX-10 and an AIM dash.
Both have enable and disable settings for the quickshifter/blipper
Should both be enabled or just one?
The reason for asking is I currently have an issue where sometimes when shifting down (but not all the time), it shifts then lurches, a couple of times to the point where the front locks as I'm on the brakes.
I'm thinking it may just be settings in the Woolich (Only on/off setting on AIM) but did wonder if the AIM and Woolich both being enabled might be causing an issue?
p.s. thanks for the previous help on here, the blip issue is the only problem on the bike after all the work done on it by a numpty over the winter.....😁
2018 ZX10R SE
When I had my 17 abs and 18 krt I used woolich to enable the autoblip or Quickshift down function, on my SE I just did it in the dash, but I have the stock dash, not even sure I have the option in woolich since the SE uses the RR ECU, I do know that certain maps can cause a mad lurching effect when autoblip is used and also if you use it without rolling all the way off the throttle it will do that too so maybe make sure you are fully off the throttle and go from there
1 - 2 of 2 Posts
