1 - 20 of 22 Posts
Yankee Racer
I have an 04 zx-10r with a dynojet quickshifter and have the "B" rod with the two male ends on it. Does anyone know the size of the male ends and the thread pitch? I am sick of these things snapping in half and also what to fabricate one a bit longer out of steel so my shift linkage will be at the proper angle.
Thanks,
JJ
i think its M6, but i'd wait till someone can confirm it
Its a M6 * 1.0
You can buy them here
https://www.midwestcontrol.com/buy.php?item=1324
This is the set-up i'm using
The DynoJet rod you need is the #32104060 rod
and order the TR6-50 rod from here
On a side note, if you breaking them you might want to buy extra...but not make one out of steel, if the rod don't break will might break something else more expensive. I'm assuming they break crashing? and not just snapping on their own?
ha, i guess i should look at my own info, the rod link i give you is a steel one
Yankee Racer
Its a M6 * 1.0
Thanks man. So you are sure its an M6 and the thread pitch is 1.0? I am not looking to buy one but I am having an engineer buddy of mine fabricate a few of them for me cause I keep snapping the dynojet aluminum ones. I also need it to be custom as I want it to be a bit longer since I use gp shift and want my linkage to be at a 90 degree angle instead of the 45 I have it at now. Thanks for all the info and rep sent your way.:thumbsup:
Oh and no I am having them snap on their own since they are not long enough and I am only getting maybe 3 threads into the female in so that isnt enough thus I need a longer shaft.
JJ i didn't even think of it but i have a kit to measure pitch, and size for bolts and nuts...too bad...
Yea i'm sure, it's the one i'm using, I have PPtuning rearsets with the DJ Shifter GP shift
The TR6-50 is the rod i used and its perfect for mine with the right angle, if you want one longer the also have them just order a TR6-60 or 70 same rod just longer
here's a list
https://www.midwestcontrol.com/catdisplay_short.php?pg=186
Yankee Racer
Discussion Starter #13
Hillbillie Mod
for lame ka bobs!
1 - 20 of 22 Posts
