1 - 10 of 10 Posts
I have a 09 zx10r with pcv quickshifter and expansion module. I checked all my connections and I can't get the quickshifter to work. I set up the rpm and Ms already also I called dynojet and they weren't very helpful. When ever Im on the gas and try to shift it wont cut the motor at all and the shifter wont even budge i don't know if they sent me a bad sensor or what. So I was just wondering if anyone else had similar problems.
did you use the software to turn the shifter on?
Yea.I set it to engage at 6k rpms to test it and I kept the 65 ms. When I talked to dynojet I asked them about software and they told me the pcv already has it and u don't need new software.
Are you using the appropriate sensor for the PC-V or maybe an older version (like for the PC-III) ?
I honestly don't know. I didn't know there was different ones for the 2 pcs. From my knowledge I thought u just need the sensor and expansion module.
Actually the sensors are the exact opposite... You need a normally close sensor for the quickshifter to work on the PC-V. The PC-III sensors ( and almost all the other sensors out there ) are normally open....
If you have a multimeter set it to continuity test or Ohms... If you connect the 2 wires from the quickshifter it should buzz or show 0 ( zero Ohms)...When you press the sensor the buzz should stop and the multimeter should show infinity ( usually displayed as 1. )
That's how a normally closed sensor should work,QEM will only work this type of sensor...
Discussion Starter #8
Ok thanks ill have to check
Also make sure you have the latest firmware in ur pcv...
Where would check to see if I have the latest and where can I get the latest firmware. Thanks
Discussion Starter #10
so i updated to 1.3.3 then i tried updating my firmware to 1.4. i hooked up the usb to the pcv then went to update firmware selected 1.4 then there was an eror now my bike dosent even start:BangHead: i tried updating it again and it was sucessfull but the bike dosent start. now i have to wait until monday to call dynojet
1 - 10 of 10 Posts
