1 - 7 of 7 Posts
Im about to head to the track w/ the 10, need to pull the headlight bulbs, which are easy, what about those little fuckers in the front? is there an easy way to get them out... i havent really looked closely to finger it out, they look like they could be a PITA to get out... any info?
thanks gang.. :dontknow: :dontknow:
why must i do everything the hard way :dontknow: :badteeth:
:heyyou:
Administrator
if you do want to pull the running lights, just look under the nose. there is one small screw, take it out and the panel comes off. Then just pull those two little fuggers :mrgreen:
Supercharged Mod
The reason for disabling the headlights is so that the heat doesn't melt the tape into an un-removable mess. For the main bulbs, it's an issue. For the little running lights, they're so small that the heat from them isn't a concern.
1 - 7 of 7 Posts
