1 - 6 of 6 Posts
Anyone have any experiance with using a Dynojet quick shifter on a 2004 Zx10r? If so would you recomend it? did you need the ignition modle along with a PCIII or can you just use a PCIII? Were you able to hook it up with the standard street pattern shit or do you have to change to GP shift pattern?
There are tons of threads on quick shifters. DJ, Bazzaz, annatori, translogic, etc. you can read all there is to read on them. Search term = "quick shifter"
you dont need a ign module just a pc and dowload the software off DJ website... depends on if you get the push or pull type QS if you can run regular or gp shift.
if you want it to run properly, you do want an ign mod with a pc3. cutting spark is much better than cutting fuel
1 - 6 of 6 Posts
