1 - 6 of 6 Posts
Ok I've read as much as i could find.
So far the ONLY questions i have are.
1. I've read some use the zx14 spring? Is this on the busa or zx10 shock?
2. I know somebody with a gen 2 busa shock with a zx14 spring.
Would this be more stiff than a busa spring on a busa shock?
Thanks
Discussion Starter #2 (Edited)
After more searching I've found the busa spring is stiffer than the zx14.
Busa 14.5kg/mm
ZX14 9.7kg/mm
The busa would be better for me. According to racetech's calculations.
Entering my weight on racetech.
Says i need a 12.196kg/mm
Im thinking after lowering and stretching +6" it should be in the right range with 14.5kg/mm.
1 - 6 of 6 Posts
